radio and i drive not working in e60 5 series!!!!!!!!!!! - BMW-Driver.net Forums
Go Back   BMW-Driver.net Forums > BMW Models > 5 Series
User Name
Password
Register FAQ Members List Calendar Mark Forums Read Advertise Auto Loans
Reply
Thread Tools Display Modes
  #1
Old 25-Apr-2011, 03:16 AM
stephen bawn's Avatar
stephen bawn stephen bawn is offline
Junior Member
Question radio and i drive not working in e60 5 series!!!!!!!!!!!
the i drive system and radio/cd player started flashing on and off and then just cut out completely,will not even turn on now,what could this be,any 1 know where the fuse is for it ,or is it a bigger problem,advice wanted,thanks
Sponsored Links
Advertisement
  #2
Old 25-Apr-2011, 10:44 AM
KnockinShop KnockinShop is offline
Member
Default
May not be any help, but there is a way to reboot them. On mine, it's holding the 2 eject buttons, and pressing the volume/mute button. Not sure how this works if you don't have the second nav dvd drive.
__________________
E60 530d M Sport.
  #3
Old 25-Apr-2011, 11:16 AM
mr_gtinche's Avatar
mr_gtinche mr_gtinche is offline
Member
Default
Sounds like your IDrive screen and controller. Common problem in E60. Dealer job for this I am afraid. I hope its still under warranty as they can be expensive, about €1500 I m told.
__________________
04 E46 320 Ci M Sport Convertible (Present)
10 E60 520 D M Sport Saloon (Sold)
09 E60 520 D M Sport Saloon (Sold)
06 E60 525 i M Sport Saloon (Sold)
05 E60 520 i M Sport Saloon (Sold)
02 E39 M5 (RIP)
01 E46 320 i M Sport Saloon (RIP)
99 E46 318 i Se Saloon (Sold)
96 E36 318 i Se Saloon (Sold)
92 E36 318 i Se Saloon (Sold)
  #4
Old 25-Apr-2011, 11:20 AM
525d 525d is offline
Junior Member
Default
Happened to my E60 last year. Had to get the CCC unit replaced. I think it cost close to 1500 which included it being reprogrammed.
  #5
Old 25-Apr-2011, 11:30 AM
Junior Member
Default
i know where there is a crashed one,what do i need to take out of it
  #6
Old 25-Apr-2011, 11:42 AM
Junior Member
Default
I don't know how to take the unit out but make sure you have the correct one as I know there's 2 or 3 different units
  #7
Old 25-Apr-2011, 11:58 AM
D.R car audio & security's Avatar
D.R car audio & security D.R car audio & security is offline
087 6343208
Default
I know its not the best solution in the world but if it
Were mine I'd disconnect the battery leave it disconnected for about five mins
And keep ur fingers crossed!!
Again just as a check process I'd pop the radio out also see If the radio itself is getting a power supply than u can rule out fuse/power problem.
You don't really have anything to lose if u try those steps
Hope it not the problem suggested in above replies!
  #8
Old 25-Apr-2011, 02:37 PM
Rich Rich is offline
Senior Member
Default
I had the same problem and it turned out to be the alternator relay in the boot. was causing the car to stop charging the battery and run into the batteries power instead, and then it would go haywire. i had it cut out once but most times it kept ticking over, just all the electric stuff was giving up.
  #9
Old 25-Apr-2011, 11:15 PM
Junior Member
Default
where is the fuse for the radio and i drive,i know there in behind the glovebox but what number is it,i have no i.d board to tell me which fuse is for what
  #10
Old 26-Apr-2011, 06:27 PM
mr_gtinche's Avatar
Member
Default
Interestingly it is a known problem with seals on the E60. The seals are renowned for leting water into the boot and the water tends to accumulate in the boot around the controller unit for the Idrive which is near the battery. Check the boot for wetness and hope its wet as this could be your problem. If it is it will save you €1500.
__________________
02 E39 M5 (RIP)
Thanks From:
stephen bawn (26-Apr-2011)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
