E46 Valvetronic internal fault (2A67) - BMW-Driver.net Forums
Go Back   BMW-Driver.net Forums > Technical Discussion > Engine & Tuning > Coding & Diagnostics
User Name
Password
Register FAQ Calendar Mark Forums Read Advertise Auto Loans
Reply
Thread Tools Display Modes
  #1
Old 12-Aug-2012, 12:59 AM
mint-e46's Avatar
mint-e46 mint-e46 is offline
Member
BMW Driver
Unhappy E46 Valvetronic internal fault (2A67)
Car (2005 316i) developed a problem last night with warning lights: check engine and EML coming on. Went into limp home mode. Brought it straight to mechanic and had a diagnostic which showed 2 codes:
2A67/2A6B Valvetronic internal fault.
I know that most likely that this unit will have to be replaced, does anyone have experience for this type of fault such as estimated cost/duration/approved garages around Limerick
Thanks in advance
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
  #2
Old 15-Aug-2012, 12:17 AM
mint-e46's Avatar
Member
BMW Driver
Default
Thanks for the reply, Car is at BMW Specialist Clondrinagh Motor Centre on Ennis road, pretty sure Servomotor is what I was told what was faulty, also vacuum hose to be reconditioned, rocker cover gasket to be replaced as it was leaking slightly (had bought it already for planned service at end of month) and ignition coil also fecked.
Full service in 2 weeks time with all fluids replaced (brake/gearbox/oil/coolant), plugs, filters, anti roll bar links replaced.
Spending a bit more on the car this month than I planned but at least I will have peace of mind
Reply
Quick Reply
Message:
Smilies
Options
Register Now
In order to be able to post messages on the BMW-Driver.net Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Security Question
While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of.
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vB.Sponsors
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
