E38 front ABS Sensor replacement - BMW-Driver.net Forums
Go Back   BMW-Driver.net Forums > Technical Discussion > Suspension, Braking & Transmission
User Name
Password
Register FAQ Calendar Mark Forums Read Advertise Auto Loans
Reply
Thread Tools Display Modes
  #1
Old 19-Dec-2012, 02:51 AM
Eric Cartman's Avatar
Eric Cartman Eric Cartman is offline
e38 735i
BMW Driver
Default E38 front ABS Sensor replacement
So i got a new sensor off ebay , tried to remove the old one but the bolt was siezed , so using a very careful method of a screwdriver and hammer I chipped away at the plastic so I could get access to the bolt. That I managed and it came out cleanly. I now have a slight problem in that the remainder of the sensor is still stuck in the hole. Any suggestions on removing it easily ?
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
  #2
Old 19-Dec-2012, 09:11 PM
ValdelisBMW ValdelisBMW is offline
Senior Member
Silver Member
Default
drill it out
  #3
Old 24-Dec-2012, 02:30 AM
e38 735i
BMW Driver
Default
managed to pull it out, new sensor in and still the 3 lights on, INPA says its an open circuit error so either faulty wiring or faulty ebay sensor, I shall know more tomorrow.
  #4
Old 07-Jan-2013, 11:18 PM
e38 735i
BMW Driver
Default
Got the sensor out , replaced , still open circuit error according to INPA
Got another sensor off the ebay seller, still the same issue .
Rewired the sensor all the way to the abs module to check , still the same.
Checked the abs module with a multimeter , one of the pins (15 or 16 cant remember) is giving me a resistance to ground while the car is on, the other pin giving me nothing at all .
Also interestingly enough, started the car today and no lights were on, reversing out of the driveway lights stayed off, rolling forward they stayed off , hit the accelerator peddle a bit , abs came on on the front wheel (could feel it shudder) then all the lights back on permanently.
Im going to swap the left and right sensors to see if that makes it any better but its seeming like a module job .
Does anyone know what bba in the uk charge for a rebuild ?
Reply
Quick Reply
Message:
Smilies
Options
Register Now
In order to be able to post messages on the BMW-Driver.net Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Security Question
While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of.
Date of Birth
Your date of birth and age are displayed in several places on the forum. Only the administrator will have access to your date of birth should you choose to hide it via the privacy option below.
Month Day Year
Privacy
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vB.Sponsors
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
