OEM Style Android Screen Install E63 - BMW-Driver.net Forums
Go Back   BMW-Driver.net Forums > Technical Discussion > In Car Entertainment and Electronics
User Name
Password
Register FAQ Calendar Mark Forums Read Advertise Auto Loans
Reply
Thread Tools Display Modes
  #1
Old 19-May-2018, 12:13 AM
Dakeyras Dakeyras is offline
Junior Member
BMW Driver
Default OEM Style Android Screen Install E63
So I thought I would share some details on the Android OEM style Screen that I installed in my E63 to replace the rather dated 6.5" CCC screen that was originally installed. I had pondered a CIC (1,200) or NBT (2,200) upgrade but thought I would try this instead which worked out about 425 after import duty.
I bought the below to install, I chose this version over the many options on aliexpress as it seems the most discussed on some forums so there is some support available online beyond relying on the Chinese suppliers.
https://avinusa.com/8-8-bmw-5-series...on-system.html
This unit is listed as fitting e60/61/63/64 and I can confirm that it fits perfectly in the e63 and everything is plug and play, no tapping of cables required.
The Good:
  • Screen is a huge improvement on original 6.5" screen so almost worth it for that alone
  • Install is plug and play so the only effort comes from routing wires etc.
  • Interface looks much more current and can choose between various NBT interfaces (original interface still available for service info etc.)
  • Additional functions: Hard drive connected for storage (1TB), 15GB internal storage available, Music and movies from internal storage or hard drive, Bluetooth music streaming, Navigation (I use waze instead of google maps which runs better), Spotify, Torque, YouTube, AppStore etc.
The Bad:
  • Haven't yet managed to get screen mirroring to work either via USB or wifi however I havent found that I need it for anything
  • Android version is dated at 4.4.4 but this doesnt really impact day to day operations
  • Somewhat underspec'd compared to current gen android tablets and is noticeable in startup time and when i tried to install the latest google maps, tablet couldnt handle it so had to revert to installed version
  • As sound relies on AUX input car always diverts to radio so you need to set this every time you start the car
  • No netflix available, I believe this is because Netflix doesn't work with unofficial/ rooted android devices
  • Changing to original interface is now stretched but this is minor
  • Had some issues with sound being low volume at the start and had to spend some time installing various android apps and making changes to resolve following forum threads but ultimately it resolved itself
The worth mentioning:
  • Automatically switches to a screen showing dynamic reversing lines which has driven me to get a rear view camera, currently wiring to the boot completed. Need to remove the bumper to install a camera but tested and works great
  • Input for DVR also has me searching for a dash cam that I can install
Overall 9/10 (point missing as newer hardware and android would be an improvement), would buy again and can recommend for anyone looking to upgrade their existing screen, particularly from CCC without navigation
Link to some installed photos: https://imgur.com/a/Jp8gMgI
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
  #2
Old 10-Jan-2019, 12:02 PM
Munzab Munzab is offline
Junior Member
BMW Driver
Default
The Good:
The Bad:
Hi. long shot
can i ask you, did you have to remove trim and a big job to open or did you get it done by someone?
Is the idrive button working and steering wheel? does it have bluetooth? i dont have bluetooth/mic in my e60 and would like this as a solution.
does it connect to the phone to get internet so can use waze? and easy to input addresses?
  #3
Old 12-Feb-2019, 03:14 PM
Junior Member
BMW Driver
Default
going to be getting an android unit for an e60. did you install yourself or used someone? i need to find someone to do the install around the dublin area.
Reply
Tags
android, e63, idrive
Quick Reply
Message:
Smilies
Options
Register Now
In order to be able to post messages on the BMW-Driver.net Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Security Question
While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
