I see a lot of ///M's and they are 50/50 Manual/SMG. The upgraded paddles look good and I believe the only difference in the CSL box and SMGII box is the actuator that allows the CSL quicker gear changes? Can anybody shed any light? Barry/Mark/Phil?
I think you're right, but for all SMG cars there's a "standard" control unit & a programmable control unit available. I only know this as I checked bmwfans.info for my own SMG car & it shows these options.
Smg from an E46 could work on a race car but it is very limiting in many ways
The car will be a fair bit heavier with smg and you are limited to the standard engine ECU and loom which can be a nightmare on a race car . You can't really change the diff ratio either as the blip on downchange won't match the speed of the car which will wreck the box eventually . You must also use the std flywheel setup which weighs a ton and will kill the car getting out of slow corners
I would advise anybody building a car with the S54 not to use the std ecu because it can be a nightmare
Nice in theory but as Mark has pointed out, there are far too many disadvantages.
Even doing away with the standard E46 flywheel alone and using a lightweight item would compensate for your granny changing gear while she's doing her knitting behind the wheel.
Apart from all that, say good luck to reliability. Nothing wrong with the standard manual box, and as mentioned, it will be a quicker gearchange.
I'm not sure I can agree on the standard ecu - it depends what you are trying to do with it. If you don't need autoblip or datalogging it does a great job of running the engine. Are you buying some sort of beemer race car anyway Brian?
yes but what if you give it a kick up the arse and tell it to forget about half the shit that it would be looking for that might not be there on a race car
Obviously standalone is the best option but your talking about 1000-1500 quid for something like a DTA S100 ECU etc and then find somebody to map it and so far I don't really know anybody in Ireland at least that can get a S54 with the vanos still intact running properly or even get much gains even with the use of standalone.
I do , hell i even raced his car , i think he postse here an odd time .
@Fitzer .
If its the blue one your looking at in the uk or the one in denmark then it would most certainly be cheaper to build one.
Iv enquired about them both.
If its not i can pass on the details.
Drifting its a 180sx with an rb25 forging all internals going for a GTX 3076R Garrett turbo bigger injectors etc[/QUOTE]
M84 should do everything you need no problem
Related Threads
BMW-Driver.net Forums
655.8K posts
14.3K members
Since 2003
A forum community dedicated to all BMW owners and enthusiasts. Come join the discussion about performance, modifications, tuning, specs, classifieds, troubleshooting, maintenance, and more!
