Inpa ediabas - Page 2 - BMW-Driver.net Forums
Go Back   BMW-Driver.net Forums > Technical Discussion > Engine & Tuning > Coding & Diagnostics
User Name
Password
Register FAQ Calendar Mark Forums Read Advertise Auto Loans
Reply
Thread Tools Display Modes
  #11
Old 29-Sep-2011, 01:03 PM
dave's Avatar
dave dave is offline
E46 320d SE
BMW Driver
Default
The battery and ignition dots are not turning black but I am trying the radio function.
I applied a fix I read in the FAQ manual to change the OBD.ini file to add (UBTT=OFF) but it just turns the battery dot black all the time even if not connected to the car, so I put it back to normal again.
I think its if your laptop has no pin No: 9 on the RS232 or something.
Would I need a null modem cable to act as a cross over between car and PC card?
Is it worth trying another card or a usb connection instead?
Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
  #12
Old 29-Sep-2011, 01:08 PM
voxpop voxpop is offline
E39 523
BMW Driver
Default
Im using a pcmcia card connecting to a 97 E39 - works like a charm. I did have to change the com port to com 1 (i think - was a long time ago). It wouldnt work when using a virtual com port. This is the com port that the pcmcia card is emulating
  #13
Old 29-Sep-2011, 02:01 PM
rebel.ranter rebel.ranter is offline
Senior Member
Silver Member
Default
Quote:
I was just making the point that PCMCIA needs to be set up right too. I wouldn't go changing the UBATT setting, there's no need & if you want to set up DIS/GT-1 at a later date it would be much better to have the UBATT change properly.
OP, just check what port your PCMCIA appears in the Device manager as, you can then change the port to match what you see in the obd.ini file.
I had an issue with a PCMCIA card set up for this (for someone else), you might be better using Com 5 rather than Com 1, try that.
__________________
1996 320iC /2002 525iA Sport /2006 630i SMG Sport
Thanks From:
dave (29-Sep-2011)
  #14
Old 29-Sep-2011, 04:28 PM
dave's Avatar
E46 320d SE
BMW Driver
Default
Thanks a million for all the help. At least I know it can work with a PCMCIA, I tried a usb and another card but no luck so it must just be a setting.
I'll try the messing with the COM's and see how it go's.
If it doesnt work is there a simplier setup, or cable/software setup I could use? I have an airbag light on from removing the drivers airbag in the door when fixing the window?
  #15
Old 29-Sep-2011, 08:18 PM
dave's Avatar
E46 320d SE
BMW Driver
Thumbs up
SUCCESS
I switched to COM 5 and for whatever reason it worked a treat, I've even cleared my airbag light.
A big thanks to Rebel.Ranter for the consistent posting and help, a credit to driver.net.
  #16
Old 20-Aug-2015, 09:20 AM
Gumi Gumi is offline
Junior Member
BMW Driver
Default Help me
I have and old laptop whit true serial port, and i Install my tiny ads interface and i got this error message, error compiling script file, my battery and iginition dots works fine but, i cant acces my E36, to test my engine, airbag
  #17
Old 23-Aug-2015, 09:55 PM
Senior Member
Silver Member
Default
Have you run ADSSETUp.exe, set your interface in ediabas.ini to equal ADS? You need to restart your computer after doing these changes. You need to be in ADS mode to work with an e36.
__________________
Reply
Quick Reply
Message:
Smilies
Options
Register Now
In order to be able to post messages on the BMW-Driver.net Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Security Question
While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of.
Log-in
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
