My car had the NCT yesterday and failed on corroded rear brake lines - although it actually passed the braking tests.
I've done a search and it seems that this is a common problem, what I want to know is roughly how much it's going to cost to fix and can anyone recommend somewhere to get it done in Dublin?
Thanks,
Steve
The rasp is addictive!!
Thanks,
Steve
If its just surface rust corrosion which it is because other wise your braking would be shit.
Just get sand paper at it and give it a coat of hammerite. it will pass then
Well I think you would be doing well to get it done for 150 ciarans friend must have known someone.
The fuel tank will need to be dropped slightly and the exhaust maybe also
