Hi all,
Posting this as I've been asked and there is so much sh1t posted about it by clueless fools.
First thing to get out of the way is basic - YOU DO NEED TO REGISTER battery replacements on BMWs with an IBS (Intelligent Battery Sensor).
These systems use 'smart charging' and they only operate correctly if the vehicle is 'told' what type and amperage battery it has. For those in the trade; think back to the Ca battery that was fitted to 1999 Focus - and things have moved on impressively since then.
With BMW you now have to think is it AGM Battery or Standard Battery. Standard = normal lead acid.
Case 1:
You're renewing the battery with identical replacement.
You register replacement to let the car know that the battery is new and the charging profile is adjusted accordingly.
If you don't the vehicle will charge for an old battery and cause premature failure.
Case 2:
You fit an AGM in place of a Standard LA battery (or vice versa)
If you don't register the replacement then it will fink up the new battery for similar reasons to Case 1 but even worse than that the charging profile will be for the incorrect type battery and cause even faster battery failure.
In this case you MUST use a 'conversion' to change the battery type. Then, register a replacement.
Using F10 as an example. I've never seen one that did not have option -A090 in vehicle order from factory. That's 90Ah AGM battery.
However, you CAN fit a standard LA battery but you must 'convert' the Vehicle Order to -B090 (which is 90Ah Lead Acid battery).
This changes the charging profile and also affects how the Start/Stop system works (for vehicles with EfficientDynamics).
If not done correctly and you get premature battery failure I know of cases where Bosch and Varta have denied warranty due to internal damage to the plates.
[phone ringing so I'll update this later in the week]
Case 1:
Case 2:
