1 - 1 of 1 Posts
Hi guys was just researching this & came across the following, I'll follow up with screen shots when the time comes:
The CBS reset procedure in Gt-1/DIS is found under:
Diagnosis -> Function Selection -> Service Functions -> Maintenance -> CBS Reset -> Test Plan
Then highlight the listed procedure and press the bottom right corner green arrow to the right. The original value of the individual
CBS service item will be deleted during the reset procedure.
Note:
The first vital step of the reset procedure is to verify the DISplus or GT1 correct date and time: "Are the current date and time correct?"
This is important for time and distance-based service items that are managed by the Instrument Cluster, because the internal vehicle trip
odometer and vehicle data will be synchronized with the internal Tester data. Confirm by either pressing Yes or No
To reset DIS time/date:
(if required, correct date and time in Main Menu - Administration - DIS - Date/Time). Then select the bottom right corner green arrow
to the right.
The next screen offers 3 selection menus:
Selection 1: CBS reset
Engine oil
Microfilter
Front Brakes
Rear brakes
Vehicle check
Selection 2: CBS reset
Spark plugs
Brake fluid
Coolant
State Safety inspection
Emissions inspection
Selection 3: End
To properly complete the CBS reset, the date and time of service/maintenance will be transferred to the vehicle. This includes setting
the day counter and the date. The transfer completion is confirmed by: OKAY in the setting status.
The CBS vehicle data correction allows "quick access" to correct or change the basic data stored in the vehicle after the CBS reset.
This procedure is found under: Diagnosis - Function Selection - Service Functions - Maintenance - CBS Correction, Vehicle Data - Test Plan.
Then highlight the listed procedure and press the bottom right corner green arrow to the right. Please verify the correct date and time of
the DISplus or GT1 before proceeding.
The next screen offers 4 selection menus:
Selection 1: Correction
Engine oil
Microfilter
Front brakes
Rear brakes
Vehicle check Selection 2: Correction
Spark plugs
Brake fluid
Coolant
Emissions inspection Selection 3: Correction
Telephone numbers
Date of first registration Selection 4: End
Note: CBS reset and correction may be required if a control module has been replaced or reprogrammed.
Please refer to the Service Information
SI B09 05 01, Introduction of Coding, Individualization, Programming (CIP) attachment #3, CBS Plausibility Check Sheet and attachment #4, CBS
Correction .
1 - 1 of 1 Posts
