BMW i8 First Impressions
5168 Views 11 Replies 8 Participants Last post by  bryanmc650
4
What is it?
The BMW i8 is the second model from BMW’s new i brand. Driven here for the first time in prototype form, the low slung coupé is planned to go on sale in the UK next April at a price that will, BMW officials hint, pitch it into direct competition with the conspicuously more conventional Porsche 911 Carrera 4S, which retails here for £87,959.
A more extrovertly styled roadster version of the advanced hybrid, which boasts an official fuel consumption figure of over 113mpg and average CO2 emissions in hybrid mode of under 59g/km, is also under development at BMW’s Munich-based R&D centre, although it isn’t likely to see local showrooms until 2015.
Billed as a progressive sportscar, the i8 was first shown in concept car guise at the 2009 Frankfurt motor show. At the time, it ran a diesel-electric hybrid system. However, it has since made way for a petrol-electric set-up that shares various components, including its main electric motor, with the BMW i3’s exclusively electric driveline.
Like its smaller sibling, it can run in pure electric mode, but only for distances of up to 22 miles and a top speed of 75mph owing to its relatively small battery. Overall range promises to be quite spectacular thanks to a 42-litre fuel tank that is mounted underneath the rear seats. BMW is not prepared to make a figure official but it is already quite clear that the i8 will be among the most fuel efficient sportscars ever placed into production.
The i8’s styling has evolved during the four-year development phase, although the basic silhouette and flamboyant layered body design has been retained, giving the i8 a strikingly futuristic external appearance which is carried through to the snug two-plus-two interior. Length, width and height are put at 4689mm, 1942mm and 1293mm respectively, making it 449mm longer, 152mm wider and a scant 3mm taller than the second-generation BMW Z4 – a car against which the new BMW has been extensively benchmarked.
As with the i3, the i8 makes extensive use of carbonfibre and aluminium in a bid to offset the inherent weight of its advanced driveline. A so-called Life Module fashioned from carbonfibre forms the main structure, to which BMW has attached carbonfibre-framed doors and aluminum sub-frames both front and rear.
The outer body is a combination of carbonfibre (roof), aluminium (bonnet and outer door panels) and composite plastic (bumpers, fenders). BMW has also revealed the i8 will be the first production car to make use of Gorilla Glass – as seen on the latest smart phones. It is used for the rear window, providing added sound deadening properties for the interior.
A definitive figure is yet to be revealed, though the i8 is claimed to weigh less than 1490kg – undercutting the two seat Z4 sDrive35iS by 35kg despite providing accommodation for up to four adults (at a squeeze) along with 150 litres of luggage space underneath a liftback-style tailgate at the rear.
The primary form of propulsion for the i8 comes via a compact, turbocharged 1.5-litre three-cylinder petrol engine – the same B38 designated unit earmarked to head into a production version of the BMW Compact Active Tourer and third generation of the modern day Mini in 2014, albeit in a milder state of tune than the 2.0bar of turbocharger boost pressure used on the i8.
Mounted transversely behind the cabin, the aluminium block unit delivers an impressive 228bhp, giving it the highest specific output of any existing BMW engine at 152bhp/litre, along with 236lb ft of torque – all sent to the rear wheels via a six-speed automatic gearbox boasting a conventional torque converter.
The efforts of the compact petrol engine are supported by two electric motors, the larger of which is mounted up front within the front axle assembly, which is shared with that on the four-wheel drive BMW 650i xDrive. With 129bhp and 184lb ft of torque, the unit channels drive through a two-speed automatic gearbox.
The front electric motor is used to drive the front wheels during the start-up phase provided there is sufficient charge within the battery, a 5kWh lithium-ion unit that is housed within the centre tunnel, providing the i8 with zero local emission capability – something that will enable it to enter sidestep city charges like that in place in London. It also chimes in to boost performance in combination with the petrol engine, providing the i8 with four-wheel drive capability
There is also a smaller electric motor with 13bhp and 81lb ft sited at the rear next to the combustion engine. But while it is capable of providing additional drive to the rear wheels, it is principally used as a generator to top up the battery and alternatively as an alternator to collect and store kinetic energy during braking and periods of trailing throttle.
Interestingly, the rear electric motor is also used to smooth out delivery by providing direct drive to the rear wheels as the petrol engine is brought into the drive process. In doing so, BMW claims to have eliminated a slight dip in delivery due to typical turbocharger lag.
BMW quotes a combined 357bhp, endowing the carbonfibre intensive i8 with a power-to-weight ratio that betters that of the steel-bodied Z4 sDrive35i at 240bhp/tonne. Combined torque peaks at 420lb ft, some 44 per cent of which is available the moment you brush the throttle thanks to the inherent qualities of the electric motors.
As with the i3, the i8 receives three distinct driving modes: Comfort, Sport and Eco-Pro – all of which involve a combination of electric and petrol engine propulsion, albeit with different throttle, steering and damping mapping.
Underpinning BMW’s new age supercar is a largely aluminium chassis boasting double wishbones up front and a five link arrangement at the rear. The latter set-up is mounted directly to the aluminium sub-frame that supports the combustion engine and smaller of the electric motors. In keeping with BMW engineering philosophy, the new car boasts what the i8's project leader, Carsten Breitfeld, describes as a "near to perfect 50:50 weight distribution". The electro-mechanical steering system is borrowed from the X3, albeit with unique programming that aims to provide the i8 with sharper reactions.
The standard-fit wheels are aerodynamically optimised and measure 20 inches in diameter. They are 7.0 inches wide up front and 7.5 inches wide at the rear, shod with relatively narrow and high profile 195/50 and 215/45 tyres respectively. Buyers will be able to order more conventional 20in alloy wheels with wider 215/45 and 245/40 profile rubber – as fitted to the car i8 prototype we drove – for added grip.
Should I buy one?
I was worried the i8’s on-road ability would be compromised by its high-tech driveline and all the ancillary components that go with it – too complex, too heavy and skewed too much towards ultimate efficiency to make it much fun to drive. And after talking to the team responsible for its engineering, it seems as though BMW was quite concerned too – at least when they conceived the distinctly new-world coupé back in 2009.
That is why the German car maker has spent big on carbonfibre construction technology in a move that will see them bring the i8 to market early next year at a weight that undercuts many conventional two-door rivals at the scales and also endows it with the lowest centre of gravity of any existing BMW model. In doing so, it provides the basis for what is truly a landmark car.
After a brief stint in the thinly padded driver’s seat of this engineering mule, we’re confident the production i8 will live up to its billing as a sportscar. It is no track weapon – not in the traditional sense, at least. But it delivers the sort of response, directness and handling prowess that I’m sure will not only see it appeal to early adopters in search of something out of the ordinary but traditional driving enthusiasts as well. And nor does it lack for pace.
The i8 is an utterly intriguing, unreservedly fun and fantastically addictive car to drive, combining a multi-faceted drive system that is strong enough to propel it along at quite a furious pace together with engaging dynamic qualities that make it terrific fun on the track. And with a few tweaks to dial out that initial understeer, it promises to be even more exciting to pedal at the limit.
Porsche 911 Carrera 4S versus BMW i8 coupé? Old world versus new world. Expect it to be one of next year’s most anticipated comparison tests.
BMW i8 prototype
Price TBC; 0-62mph sub-4.5sec; Top speed 155mph; Top speed (electric) 75mph; Economy 113mpg; CO2 sub-59g/km; Unladen weight 1490kg; Engine inline three cylinder, 1499cc, turbocharged with synchronous electric motors Combined power 357bhp; Combined torque 420lb ft; Gearbox 6-spd automatic
More here:
http://www.autocar.co.uk/car-review/first-drives/bmw-i8-prototype-first-drive-review
See less See more
Reactions: 3
1 - 12 of 12 Posts
I'm sure that's the car we saw near the M Division of BMW as it was parked up on a side road and wasn't coming out until we had all gone, a certain "expert" thought it was an Audi but we learned not to listen to him
Saw this at the Frankfurt motor show today- it's absolutely stunning! Wouldn't say no to an i3 either though!
6
I've seen the show over the weekend. Have few photos of BMW i8 from IAA. I love it
See less See more
Reactions: 1
I was over on 13th and 14th and have to agree that this is a stunner in the flesh. It has the potential to be a game changer in people's perceptions about EV/Hybrid cars. This may do for hybrid what Tesla is doing for pure EV's.
This is from a petrolhead that still can't bring himself to buy a car with a tractor engine. :)
How much is it supposed to cost in Ireland? I think the i3 will have the potential for the biggest impact on the car industry, but again it depends on the price point. I think I read the i3 would be €33k.
There's a serious amount of tech behind both of them including the carbon fibre chassis which I wouldn't have expected on an i3!
The only price indication for the i8 so far, afaik, is that it will be more than €100k and less than €200k in Germany.
I'm guessing it will be targeted at an Audi R8 level of the market.
Reactions: 1
I've had a go of the I3 and it has plenty of poke when you put the foot down. I'd say it will be a game changer alright.
1 - 12 of 12 Posts
