I thought I had a problem with my car kit but now i believe its got to do with the rear lights. if you look at the photo I took the left brake light isnt as bright as the right one. Also, the rear fog light on the right is much brighter than the left one. The left foglight is only measuring 4 volts and the right one is measuring 8 volts. Both brake lights are measuring 11.5 volts.
So far I've fixed the earths on the rear lights. They were totally gone so I attached the earth wire to the earth bar on the bulb holder frame.
I have an issue with a relay underneath the fuses. its the 3rd one in from the door (http://www.realoem.com/bmw/showparts.do?model=AL71&mospid=47634&btnr=12_0495&hg=12&fg=35&hl=31 number 6) that randomly clicks. when i opened it I saw some burning on the inside of the housing and some carbon build up on the contacts which i cleaned with some sandpaper. I swapped it with the good one beside it but the clicking still persists so it must have something to do with the earths on the rear lights.
Does anyone know what that relay does and could i be connected to a bad earth on the rear lights. What other earth points should I check next?
