1 - 11 of 11 Posts
2002 Touring
having trouble figuring it out and google isnt helping me
Can it be switched off completely?
when i start car, light comes on and goes out
any bit of slide and light flashes on and cuts power, fine so far
from stationary, when i press the button i can either turn the light on full time or off and traction control will still cut in at any bit of slip
and finally, i press and held in button for 10 seconds as per google advice, light goes out but still t/c cuts in
Any thoughts?
Its a handy tool, but i'd like to be able to turn it off when i want
E39 530i
Like David above, when I press the DSC button, the light illuminates on the dash and traction/stability control is disabled. The car will slide/spin no problem.
When you hold down for 10 seconds, the light on dash will briefly illuminate and then go off again (still holding button). Some people have coined it 'Easter-egg mode'. A bit more info on it here. The info on it is a little bit vague/unofficial, but I noticed a difference in DSC characteristics when I tried it.
But either way, if you press the button and the light comes on (which means DSC is off) then you shouldn't have traction control activating in any situation.
You sure about that? If I press the DSC button, I get the warning light. Asc control is disabled but DSC is still activated.. But when I hold it for 5 seconds both dsc and asc is disabled and I get the yellow handbrake warning too
E39 530i
It must be different for the E46, only the DSC light is affected by the DSC button on the E39 ('01). When I press the button, everything is deactivated. Traction control, and stability control. Did it on track, I had no input from the DSC system - haven't had a chance to try out that easter-egg mode thing properly though to see exactly what it does. Maybe next time!
2002 Touring
OK, thanks for the replies, turns out, my initial assessment was wrong, when you press the button and the light turns ON, the ASC turns OFF!! Thats not very smart!
Anyway, just glad to know that it can be turned off as i had a moment last week when i needed the power to pull me away and all i got was BAAAHHH...... Not good when you're not expecting it
something doesn't add up though, you needed the power to get you out of a bind, the traction control kicked in, which means loss of traction, loss of traction is shit tyres. Never had an issue with traction in my car.
2002 Touring
it just cut the power on me when i needed it most
I dont know the ins and outs of it, never had a car with it before
I suppose its a good idea but let me down when i didnt need it Ha!
Yeah when the light on the dash is on, it is telling you that its off. when it flash's at you, it is letting you know that it is working and stopping the car spinning or sliding. Like RPG said there is an Easter egg mode which allows a bit a wheel spin before it kicks in to control the car again. I have only used it a couple of times and never really seen too much difference. I have seen on other forums that the Easter egg mode is suppose to work well in snowy conditions but again I never tested it.
1 - 11 of 11 Posts
