1 - 12 of 12 Posts
As above my car is chucking and jerking when I put the foot to the floor in first gear , but is fine when I take off easy and gradually put the foot down anyone have any idea's what could be causeing this , seems to be alright in the rest of the gears .........
M-Tech 318is coupe
difficult! check all the vacuum pipes under the bonnet, look for loose fittings or any splits or cracks, could be a dirty fuel filter either...
richie_rvf
I've noticed it's not doing it first thing in the morning when the engine is cold ...
Cheers Martin I should be able to get over on monday or tuesday , Where abouts in Shankill are you ,
M-Tech 318is coupe
A big thanks to Martin for doing the diagnostic's on my car , Don;t know if this makes any sense to anyone but I'll post it anyway,I think the problem is the cam shaft postition sensor ,
Vehicle Type: BmwE36 318is
Year: 1999
Licence Plate:
Customer: Karl Vickers
www.autoremap.com
___________________________________________________________________________ Total Diagnose:
Autoremap
Shankill
Co. Dublin
1890 501999
[email protected]
CARSOFT DIAGNOSIS REPORT
W DME / DDE diagnosis - Status: ERROR -> read the error memory!
W Inst. Cluster dia. - Status: OK W SIM diagnosis - Status: Module does not respond!
W AIRBAG diagnosis - Status: ERROR -> read the error memory!
W ABS / ASC diagnosis - Status: ERROR -> read the error memory!
W BC / MID diagnosis - Status: OK W DWA diagnosis - Status: Module does not respond!
W ZKE / ZVM diagnosis - Status: ERROR -> read the error memory!
W HKL diagnosis - Status: OK W EGS diagnosis - Status: Module does not respond!
W EWS diagnosis - Status: OK W LCM / CCM diagnosis - Status: Module does not respond!
W PDC diagnosis - Status: Module does not respond!
W CVM diagnosis - Status: Module does not respond!
W CAS diagnosis - Status: Module does not respond!
W ZGM diagnosis - Status: Module does not respond!
W RLS diagnosis - Status: Module does not respond!
- - Total diagnosis completed! _____________________________________________________________________________
Single diagnosis DME / DDE - Status: ERROR!
Module Info: DME / DDE
BMS M5.2
BMW Part Nr. : 1438877
Hardware Nr. : 07
Software Nr. : 40
Diagnose index: 50
Code index : 01
Bus index : 60
Production Date: 47/98
DME52_FE.DXT
112 Singal Camshaft Position Sensor
95
- Single diagnosis completed!
Single diagnosis AIRBAG - Status: ERROR!
Module info: AIRBAG
Version : Airbag BAE (Driver + Passenger AB)
Part Nr. : 8 374 798
Hardware Nr. : 3
Software Nr. : 5
Diagnose index: 5
Release Date : 50/98
Supplier : Temic
Code index : 4
airbag5.dxt
03 Passenger belt tensioner
Power Supply (Before mod. 2000 and All E36)
16 Battery Connection 2
Belt contact driver (Before mod. 2000 and All E36)
Single diagnosis ABS / ASC - Status: ERROR!
Module Info : ABS / ASC / DSC
Version :ABS Teves
Part Nr. : 1 16 48 96
Software Nr. : 2B
Hardware Nr. : 5
Code index : 3
Diagnose index : 69
Bus index : 80
Production Date: 15/11/98
Abs2.dxt
146 CAN Error
Single diagnosis ZKE / ZVM - Status: ERROR!
Module Info : ZKE / ZVM
ZKE 4
Supplier : Siemens
Part Nr. : 8 387 529
Software Nr. : 16
Hardware Nr. : 15
Code index : 3
Diagnose index : 2
Bus index : 0
Production Date: 48/98
zke4.dxt
15 Lock Contact
62 Relay For ZV unlocking sticks
25 Pulse Generator For Front Power windows short-circuited
50 FH Drive, Driver side, Rear, stiff
M-Tech 318is coupe
forgot about that one, it happened to me before, the car wouldn't idle cleanly at all, easy fix though.
Rich.
richie_rvf
Vickers`s cousin here, i have the same car with the same problem and just wonderin is it a problem with that model ??
Discussion Starter #10 (Edited)
Right problem finally fixed the boot from the head to the airbox had cracked in the middle of one of the splines taped it up and no more chucking (thank god it was wrecking my head) , Got 318is's sorted today to , same problem
That's good to hear - nothing worse than a snag like that!!
Might help someone fix the same fault quiker in the future,
Rich.
1 - 12 of 12 Posts
