1 - 1 of 1 Posts
Vendor
If you want to lower your car to get a sportier look and get rid of the wheel gap or feel insecure about the sharp turns you attempt around the corners, adding an aftermarket lowering kit will help you out and KW is one of the best options to consider.
Here are some reasons why:
- Every spring is designed and manufactured to custom fit your vehicle and guarantees maximum handling and performance for your ride
- You'll get a perfectly aggressive stance without compromising on the ride's comfort
- KW lowering kits allow a large range of height adjustment while retaining the factory electronic damping control
- Include progressive rate lowering springs for each corner of the car, height adjustable spring perches for the front and rear, strengthened and shortened bump stops and KW shock sleeves to protect the OE dampers
- Each kit is carefully tuned to match the factory dampers on the car it is intended for
- Springs are manufactured from Silicum Steel with a tough weather resistant coating for a long-lasting and reliable service.
Get more information about KW and choose a Lowering Kit for your BMW X1 on CARiD!
KW Suspension™ | Coilovers, Lowering Kits, Lift KIts, Springs - CARiD.com
Treat yourself and your ride with KW Lowering Kit!
1 - 1 of 1 Posts
