I thought I'd create a thread in the DIY section for others for future reference if someone wanted to code them to their own car. Note these changes are to be made in the LMA module using NCS Expert, with the E90 you need to make these changes in the FRM module. Note, some of these changes are only possible for cars with a build date after 03/2007, but you can retrofit a new module to earlier cars if you really want the features.
Note: I have marked the setting I used with a star =*.
Welcome Lights
WELCOME_LIGHT_ACTIVE WELCOME LIGHTS IN LIGHTS MENU (LINKED TO [VA_WELCOMELIGHT] IN CAPPL)
aktiv enabled *
nicht_aktiv not enabled
WL_SL_1 WELCOME LIGHTS WITH STANDING LIGHTS 1
soft_einschalten soft-on *
hart_einschalten direct switch-on
WL_KZL WELCOME LIGHTS WITH LICENSE PLATE LIGHTS
DEF_WELCOMELIGHT_CKM DEFAULT CAR/KEY MEMORY FOR WELCOME LIGHTS
aktiv enabled *
WELCOMELIGHT_CKM_0 CAR/KEY MEMORY 1 FOR WELCOME LIGHTS
aktiv enabled *
WELCOMELIGHT_CKM_1 CAR/KEY MEMORY 2 FOR WELCOME LIGHTS
aktiv enabled *
WELCOMELIGHT_CKM_2 CAR/KEY MEMORY 3 FOR WELCOME LIGHTS
aktiv enabled *
WELCOMELIGHT_CKM_3 CAR/KEY MEMORY 4 FOR WELCOME LIGHTS
aktiv enabled *
aktiv enabled *
nicht_aktiv not enabled (Requires newer SW version in CAPPL/MASK than I had)
Remote Home Lights
HEIMLEUCHTEN_FUNKSCHL FOLLOW-ME-HOME LIGHTS ACTIVATED BY LOCKING WITH REMOTE CONTROL
aktiv enabled *
Also change this parameter on CAS Module:
Module: CAS:
Parameter: SONDERTASTE_PANIKALARM
New Value: panikalarm * (will be « nicht_aktiv » by default)
Brake Force Distribution
BFD_2_ALGORITHMUS BRAKE FORCE DISPLAY STAGE 2 ALGORITHM
aktiv enabled *
BFD_2_BL_M_ERSCH_BILD BRAKE FORCE DISPLAY STAGE 1 THIRD BRAKE LIGHT APPEARANCE [NICHT_AKTIV: OFF, WERT_01: ON, WERT_03: FLASHING]
wert_01 value 01
wert_02 value 01
wert_03 value 03 * (flashing)
Cornering Lights
KLS_BEI_AL_AKTIV CORNERING LIGHTS ENABLED WHEN LIGHT SWITCH SET TO LOW BEAMS
aktiv enabled *
ABSTELLPOS_SMC SWITCH-OFF CORNERING LIGHTS WHEN STEERING WHEEL RETURNS (LIKE TURN SIGNALS)
aktiv enabled *
DEF_ABBIEGELICHT_CKM DEFAULT CAR/KEY MEMORY FOR CORNERING LIGHTS
aktiv enabled *
Angel Eyes as DRLs
VERHALTEN_DRL_TFL_33 DAYTIME RUNNING LIGHTS
drl_tfl_off daytime running lights disabled
drl_s usa daytime running lights with dedicated lights
drl_h usa daytime running lights with high beams
drl_l usa daytime running lights with low beams
tfl_s * european daytime running lights with dedicated lights
DRL_TFL_SML_33 DAYTIME RUNNING LIGHTS WITH SIDE MARKER LIGHTS
aktiv * enabled
The DRL also needs a change in the M-ASK or CCC:
DAY_RUN_LIGHT
nicht_aktiv
aktiv *
Retrofit guide for LM1 to LM2 assumes you know how to use the tools:
Retrofit Guide LM1 to LM2
Thanks for putting this together.
2 remarks though
1. Many of those settings do not exist on the e89 branch, well they do, but have a different name. The fonction names you posted are only good for the E6x.
Example, the follow me home on the e89 branch FRM module is called: HEIMLEUCHTEN_ENABLE while it is called HEIMLEUCHTEN_FUNKSCHL on the E6x branch.
2. Quiet a few of those settings are non possible on LCI models on the e60 branch.
Take SONDERTASTE_PANIKALARM in the CAS for instance, you can't enable that in there in the E6x LCI cars.
Hi Rebel just reading your LM1 - LM2 guide. Is it possible to upgrade to LM2 (probably upgrade to LCI taillights at the same time) but keep pre lci adaptive xenon headlights and still utilise the adaptive cornering system? Referring to a pre lci e60 here.
Cheers :)
Discussion Starter #4 (Edited)
I'm no expert in this but I would say that you'd have no issues going LM2 with your original headlights, the LM2 is the default replacement unit if the original went faulty & you had to go to the main dealer.
Just make sure you pick up the right module for Xenons & adaptive headlights. There are loads of part numbers for these modules that aren't listed on ETK so the best idea is to be sure to find out what the donor car had (Xenons, adaptive).
I would do that job first then treat the LCI rears as a stage 2 of the project. Then you'd just follow any of the DIY guides on fitting LCI rears in a pre-LCI car.
If the link for the guide above doesn't work here is an alternate location:
https://www.dropbox.com/s/bnic9m7v4vre933/BMW e63 - LM1 to LM2.pdf
