So for a while now Ive been looking for a way to hook an Aux input to my head unit. I have the business cassette H.U, in a 2001 320D.
Everything Ive read says that, if you have the c.d head unit ,you can buy an after-market loom, plug it in the c.d changer port on the back, thus replacing the changer with an Aux input.
(provided its post 2003 i think).
But alas if you have the tape deck....forget about it.
This is true, it doesn't work, this has been said plenty of times on this forum.
I found this post:
http://forum.e46fanatics.com/showthread.php?t=818371
About a guy who wired a stereo ,3.5mm jack to twin phono lead, directly to the c.d changer loom and by doing so replaced the changer with an Aux input.
Now although he has a C.D head unit I thought I'd give it a go.
The wiring loom to my changer is different to his.
I have two plugs going to the back of my changer, one for the sound and the other for the power supply
Remove the two plugs,
You'll be modifying the sound one.
It has 3 cables: Blue/White, Red/White, Brown/White.
Its the large connector. But the easiest way to figure it out if your confused is to plug them into the changer one at a time, whichever one activates the mechanism is the power one.
Couple of things:
You loose the function of the changer, but all my music is on my IPhone and I don't really use the changer anyway.
You cant change tracks on the IPod, IPhone with either, the MFSW buttons or the H.U buttons, it has to be done on the device.
you could get something like this: http://www.amazon.com/Auxiliary-Audio-Inline-Remote-Control/dp/B001UGXC8K?tag=5336612389-20
to change tracks with.
So I hope this helps someone. it took me about ten minutes to do and about half an hour tracing the 3.5mm end up to the armrest where my phone holder is, the fun part was getting it under the [email protected]%king carpet
I found this post:
- Expose the 3 wires in the sound plug.
- Cut the connectors off your RCA cable.
- Attached to each RCA connector are White/Bare or Red/Bare cables.
- Twist the two bare cables together.
- Attach the bare cables to the Brown/White of the Changer loom.
- Attach the Red RCA to the Red/White of the changer loom.
- Attach the White RCA to the Blue/White of the changer loom.
- Reconnect the power connector ,you haven't modified,
back in to the changer. - Plug the 3.5mm Jack in to an IPod,IPhone, M.P.3 player.
- Select the changer using the Mode button on you H.U and away we go
Couple of things:
