Hi ,folks
I have a 2006 520 D .
chassis last 7 digits cp70153.
I drive is dead no power on radio or cd.
Parking sensors work , but obviously no display.
I tried the force reboot with cd eject and volume button in , but that does not work as it gets no power.
I tried battery disconnected for 24 hours, alas no joy.
On starting the car the idrive screen does not show the BMW logo.
ALL Fuses checked in glove box .
focused on FUSES 18 ,34 35 38
ALL Fuses checked in the boot too, all good .
Focsued on fuses.
59 73 75 77 80.
In the boot I checked under the spare tyre , this model is after 9/05
SO the parking sensor control is there but not the MPM which often causes idrive faults. ( micro power module).
After 9/05 The MPM
functionality was integrated into the Body gateway (KGM) Module.I understand this assigns power to different components , like the idrive, Radio etc.
I checked real oem http://www.realoem.com/bmw/enUS/showparts?id=NC32-EUR-05-2006-E60-BMW-520d&diagId=61_1717
The body module I expect is BODY MODULE part nr 61359176069
In the boot there area couple on interesting relays.
E60 520d Relay for radio signal / horn K463 the horn works,
so this is okay I expect. part number 61358350566
E60 520d Relay for radio K442 61358350566
Any thoughts what the fault could be , I am not sure how to check relays.
I thought of swapping these 2 relays as they are the same part number.This is next step.
Any thoughts/tips what the fault could be ?
:confused2:
okay launch diags shows
A46D: Malfunction CID by reset of MOST ring
A468: External open circuit ( LVDS data line)
could it be cable to screen
thx shak
Focsued on fuses.
59 73 75 77 80.
After 9/05 The MPM
:confused2:
thx shak
