1 - 11 of 11 Posts
Hi lads, I have a 08 320d e92 and am getting a DPF error message. Been told by bmw that due to the mileage (140,000 miles) it's probably due to be replaced.
Problem is its 2,500! Damn!!!!!
Anyhow, options are (apparently) to get it cleaned which is about 500e and no guarantee of NCT pass according to them
Or
I've chatted with a few lads and they recommended a bipass pipe,
Any advice welcome, if the bipass pipe is an option, anyone recommend someone around Cork that can make one up and possibly fit?
remove and get it cleaned in special machine .not terra clean on the car !!
once it be removed , visually can be seen its condition ,after cleaning they will tell u if it went perfect or something wrong ,im nearly sure all will be ok .
dont need any decats or so on . the worst , u can get second hand part and clean it ,still 3-4 times cheaper as new
Just get it properly cleaned. We've done a few of them using dpf clinic
DPF clinic???
Thanks for rhetoric suggestions folks, I'll 100% get it removed and cleaned before even thinking about replacing.
Any suggestions as to where to bring it to get it cleaned properly around Cork?
E90/E53
Cork engine centre are now specialising in this, Anybody I've spoken to has been happy with the results so far.
once it be removed , visually can be seen its condition ,after cleaning they will tell u if it went perfect or something wrong ,im nearly sure all will be ok . dont need any decats or so on . the worst , u can get second hand part and clean it ,still 3-4 times cheaper as new
1 - 11 of 11 Posts
