1 - 16 of 16 Posts
Discussion Starter · #7 ·
No worries, which one is broke? If only the indicator then it's fine, I don't need the indicators anyway! Really I only need the passenger side main headlamp part... as my full beam doesn't work there (wiring problem... my other one is fine)...
these shouldnt be hard to find at all...most of these headlights from an e36 saloon, compact or coupe will fit! there all the same! although there are one or two different brands that are slightly different inside... just head to your local breakers and you'l pick up a set handy enuff :D
Reactions: Kielo
1 - 16 of 16 Posts
