1 - 9 of 9 Posts
Hello all, I plan on doing a run of these soon pending numbers.
It is a common problem concerning the control gear that 'parks' the mirror. Due to a pretty sharp root angle on the original gears, the teeth can break off rendering the park function useless.
The new gear is a slightly revised design, in that the root is smoother leading to a stronger tooth. The gears will be made from hardened En24 steel and a direct replacement.
Gears are not handed(left/right) - Thanks Danny, so that will simplify the process a little.
This part is also small, adding to its complexity and tolerances a bit. Its just 18mm long, and around 8mm in diameter. (see pic in link)
Parts will be made via cnc to high tolerance, so no problems there.
I have no Idea on price yet as its not really a money making affair, more so to get like minded enthusiasts out of a spot but I would be aiming for around the 40euro mark per gear shaft - there is a lot of setup work with these, and initial design math even with cncs involved.
If interested, stick your name down, Ill let this run for a month or so,
http://www.bmw-driver.net/forum/showthread.php?t=41610
Thanks,
Brian,
(Thanks Dave also)
Hi Brian are you able to make control gears for the power folding mirrors that can be found on non M e39s and e38s?
I may well be interested in these. Mine are ok now, but they do go. I've allready had to rebuild both mirrors!
I've come over from another forum, but would defo be interested in it. Could I be pm'd with details if you get enough interest. Cheers
1 - 9 of 9 Posts
