Hi Guys,
So a while ago I bought a MFSW for my E46.
I had heard that it was a simple matter of plug and play so I popped it on but, alas, no joy.
I've been looking around on-line for guides on how to get it working and there is an abundance of threads on many forums but a lot of them had contradicting posts.
Anyway here are the details of my car and what I did in case anyone is thinking of doing it and wondering will it work.
BMW E46 SE 320D 2001 REG m47 Engine.
production month/year: 03/2001
it has the 'fly by wire' throttle not the servo assisted cable one.
I have the old three spoke MFSW with the triangular air bag. but I don't think this matters much.
Basically when I took my air bag out I saw that there was two small looms.
one going from audio buttons to cruise control buttons and another going from cruise control buttons to the top of the slip ring
the guides I used were:
http://forum.e46fanatics.com/showthread.php?t=544160&mode=linear
and
http://www.kneb.net/bmw/E46/Multifunction%20steering%20wheel%20and%20cruise%20retrofit.pdf
I bought the part on-line:
http://www.amazon.co.uk/BMW-Genuine-Retrofit-Cruise-Control/dp/B0052TGMJC/ref=sr_1_1?m=A2LSLB2WWMB182&ie=UTF8&qid=1337936678&sr=1-1
this was the only part I needed.
its a simple enough job, takes about 2 hours.
I had thought that I'd only get the cruise control buttons to work but to my surprise the audio ones work now as well
No coding needed
As I've said this D.I.Y is readily available on-line I just wasn't sure it would work with my car. So if any one has a similar build spec and age you should be fine.
the main thing is that the car has to have the fly by wire throttle not the servo cable type.
hope this is of some help to someone.
and
No coding needed
