1 - 20 of 21 Posts
Hey guys!
Within the last 2 weeks ive started hearing a rattling noise from my 2000 318Ci :(
I notice it happens only when i put the car in 1st & 2nd gear, it almost sounds like something is loose, i had a look under the car to the best i could, but couldnt see anything. So i wanted to see if anyone else had the same problem?
Here is a link to a video of it i tried to record :D - jump to 0.27 seconds http://www.youtube.com/watch?v=6eZSEWEApao
Now my spoiler question!
I bought the car with the spoiler on it and now i dont like it, i want to get a lip spoiler, so i wanted to know the best way to remove the spoiler. I had a quick look and its not bolted on, it seems to be glued on.
All suggestions welcome, here is a pic of the spoiler:
http://i945.photobucket.com/albums/ad299/dead_battery10/spoilerphoto.jpg
Thanks for looking :)
Holy fuck.....that sounds awfully odd....
hard to tell on the video...
could be a bearing gone on the back of a pulley? if its internal then it really does sound bad!
Hi Damo,
Thx for the reply, the car has some sort of sport exhaust on it, so could also be that? I will check out the bearings like you said on the pulley.
Cheers :)
Hi Damo,
Cheers :)
nope i wouldnt imagine so...its a proper movement noise there....something spinning of some sort...
is it louder when shes cold?
Hi Damo,
Nope she is not louder when cold, it doesnt happen when i go over bumps or anything, just the transition into 1st gear and 2nd. :confused:
Niall
MonsterShaft Member
hoping the noise isn't internal, but just a long shot here are the engine/gearbox mounts in good condition, exhaust mounts also, maybe lack of gearbox oil eventhough I doubt it's that? it does sound horrible on that video
Hi robbie,
Yes I assume they all are! I passed my NCT last week, and they had a good rummage around under the car so I assume if there was a problem they would have seen it, I will get it checked out by a mechanic and see what they say, i feel as though it could be the exhaust shaking? Its an old sport one apparantly:confused:
Thx for the reply's all :)
It sounds like a possible gearbox failure but its very difficulf to say for sure. Have you any rough idea where its coming from, front or back?
Hi Rich,
Yes deffo coming from the back of the car :(
I lay underneath while my gf slowly placed it into 1st gear but I couldn't see anything rattle, my best bet would be to get someone to throw it up on a platform and have a proper look>? Ill have another gander later and try get more info for you guys, ill take some pics too.
Cheers
Niall
for the spoiler, get some piano wire/fishing line and slip it in between the spoiler and bootlid and cut through the sealer. or get a heat gun and heat the sealer up.
If its at the back then you could be looking at a diff problem. Id check out the coupling on the prop shaft and the centre bearing too to see if theres any sign of them being the cause.
Discussion Starter #14
Cheers Kev! i gave the fishing line a go yesterday and it works perfect just need stronger fishing line :D
Discussion Starter #15
Hi Rich, i got under the car ( as best as i could ) and noticed when the propshaft is turning i hear the noise, so possibly its the culprit! can propshafts be oiled? maybe it needs some WD-40 lol
Discussion Starter #17
Just came across this: http://www.youtube.com/watch?v=OhsDaSA0ZFk
Check out the 2nd comment, sounds like the same problem: @Carnalismo88 yes... the same happened to me, usually when i was driving forward and then stop and shift to reverse it would make that clunk noise...how i fixed it? got the flex disc replace and...bingo...! (flex disc AKA guibo)
Im assuming the GUIBO is the propshaft?
Guibo is a rubber disc between the propshaft and gearbox. Google it and you'll be able to find a pic easily.
A guibo is the part i was refering to when i said "Coupling" and when they are on the way out they can make mad noises. can you take a photo of yours and see if theres any obvious signs of wear on it? It looks like this and its on the end of the proshaft.
1 - 20 of 21 Posts
