Hi guys.
Looking for some Help as I'm at my wit's end.
A previous owner had fitted led lights for the halos. They worked fine for a long time but then the driver's side went faulty. I changed for a new one with no joy. I discovered a pin in the one I took out was loose and I've repaired it. It'll work on the passenger side but not the driver's side. I've checked for voltage and getting nothing. I used tool32 to check to see if it had locked out any circuits but it's showing all circuits as ok. The eyebrow light is working so and I've checked all fuses and connections to no avail. Has anyone come across this before or know a fix?
