Hello
I have a strange problem with my 2005, 318i, N46. I've got flashing check engine light, rough idle, and power loss between 2500 and 3000 RPM and at one point the error cod P3010 gets stored but no other error codes on cold start.
After the car gets heated up, the problem with flashing check engine and power loss seems to be solved but the error code (p0301) is still there. This happens at every cold start.
After I removed the eccentric shaft sensor connector everything works fine, (except the fuel consumption goes trough the roof of course) this is why I think the problem may come from the Valvetronic, but I don't have any specific error code just P0301.
What do you think is it worth to change the valvetronic motor for example?
