1 - 1 of 1 Posts
Decided to fit the toolbox to the CSL lid tonight in between ad breaks on Nip/Tuck!
Heres some photos...mainly for Richies attention!
I wedged out the threaded insert from the old lid with a screwdriver.
I then cut out a piece of mdf into which I cut fit the insert.
This didn't need to be too neat - just needed it to support the insert. I glued the insert into place then using superglue.
I then took out the trusty isopon, and built up the sides of the mdf to be flush with the insert. I also flushed off the bottom, so that there was a relatively large surface area to come in contact with the bootlid.
Cleaned this up a bit, not too much though - as I carpeted it...Just used spray contact adhesive.
I used the same adhesive on the back of the carpet, and secured it into the bootlid. The toolbox screwed in first time - looks perfect. No photo of it at the moment though - its a bit dark out!!
Am, well happy, its beginniing to get finished off - just the reg lights and screws for the reg plate needed now.
1 - 1 of 1 Posts
