Anybody have info on tracking units or had one fitted.
Was speaking to someone about getting one,Operates through GSM by text message, Tells where the car is located, Speed it is traveling at. You can also imobolise the car by sending a text to the unit.
Never heard of any body of this side of the water with one but every second m3 in britain has some sort of tracking device. Couldnt be cheap either
So far I have two companies on line doing them, one is for € 550 +vat +€ 10 a month for the mobile subsciption.
The second I am waiting on a quote. http://www.rmdistribution.ie/ who have a couple of testomonials on there site however look expensive.
A guy I know who fits Mobile car kits can install one for 900 which will imbolise the car by sending a text to it, and lets you recieve its location.
If its anything like GPS in this country I don;t know how they can locate it??
A friend of my dad is starting to distribute a system which you install yourself - you simply find a hidden spot in the car and stick it there. Think theres a worry that the fitters can immobilise the system straight away once they know where it is! (one M3 was nicked from its owner in the UK a day about being in the garage - tracker turned off within minutes) Its being installed on new cars by Mercedes and BMW too so it must be quite decent.Might be one of the ones you're looking at.
Might be getting one of these myself in the near future though, so if you do go for one let me know how it works out! Mine has the Tracker in it at the moment, but thats no use unless I'm in the UK :(
Discussion Starter · #5 ·
Decided to go with the Clifford instead, the trakers look good however they can be disabled rather quickly, and if there is no signal, Ie they pull the antenna out you can not track the car. The system do work in ireland however, They use GSM rather that GPS.
The other down side is they can only be imobilised once the ignition is turned off, they can not restart, the Clifford will imobolise the car while its moving....
