1 - 9 of 9 Posts
I have a small coolant leak on my 320d :( and for a change the expansion tank seems to be fine, but I've spotted a small few drops coming from the top right hand side of rad when hot.
And also a small bit has collected on the undertray.
So I'm pretty confident it's not expansion tank but the radiator.
Is there a guide, or is there anything I need to know when changing?
shes about to blow :D happened me just last month started at the side then the whole rad just packed it in , pick yourself up a radiator ,coolant and do the serpinetine belts while your there
if you google e46 radiator removal you should get a few guides
oh yes when your detaching the exspansion bottle from the tubing on the top of the rad be very careful i broke the nozzle on the expansion bottle when removing luckily i had another one within the hour
Thanks Gar :)
Ya I'm picking up the rad later. How long did it take you to do?
there's a great cheap rad place near frank hogans mercedes garage in limerick. Picked up a new rad for the e36 for 120. He's on the limerick side of frank hogans
Good point Gar, you'll never have as much space again, so I may as well.
How much did they set you back? Local motor factors ones ok for the job?
id say around 3-4 hrs at a leisurely pace it was lovely out and i was chatting more than working , breaking the exspansion bottle delayed me
Cool, I'm tackling it on Friday morning, it'll be my first bit of work on a BMW :eek:
Luckily the expansion tank seems pretty solid, I'll probably crack it on Friday :D
Nice one, cheers Tommy. I picked up a brand new one yesterday from a good contact in Galway for €120 as well ;)
yep motor factors are fine bmw will just charge you mad money for the same thing i bought goodyear ones for 30 for both
Cheers Gar. The local motor factors quote me 41 for both alternator and ac replacement belts
1 - 9 of 9 Posts
