Hi guys,
I drive a 2005 320D E90.
I've noticed in the last 3 months that when I brake the steering wheel vibrates and it's getting worse. I don't notice any vibrations anywhere else other than in the steering wheel.
It happens at low speeds ~50km/h and high speeds 120km/h
All pads were replaced about 3,000km ago. Rear calipers were also replaced at the same time.
I don't drive the car much - maybe 220km every 2 weeks (I get the train to work, visit my parents once every 2 weeks ~100km away).
The front drivers side tyre has a slow puncture - it goes from 32psi to 27psi in 2 weeks.
The vibration is still there immediately after I pump it.
I also can't find where the injury is in the tyre - there is a cut in the sidewall but it doesn't look like it's deep and so I'm not confident this is the issue (although a possibility?).
My ideas:
Tyres? Could the nick in the sidewall cause this?
Solution: 2 new front tyres fitted (Cost ~€120)
Tension strut/Lower control arm replacement?
Is there any way to check if these need replacing?
Solution: Replace (Cost ~€150 + Tracking €50)
Tracking?
Could the car (wheels?) be out of alignment and need to be tracked?
Solution: Bring to garage to get tracking fixed (~€50)
Balancing?
Wheels need balancing?
Solution: Bring to tyre fitters to balance, or maybe just get new tyres altogether (Cost ? / ~€120)
Anything else to suggest?
My initial thoughts also were a warped rotor, but after some reading some people suggest that modern rotors do not warp.
Thanks for any help!
My ideas:
Tracking?
Balancing?
