Hi a while back my car has started to make a knocking noise just when i turn the engine off!? it dosnt do it on start up are when driveing!....Any ideas what it could be?
I'm a 2 wheel man really
could be engine mount gone, and shudder when switching off is causing it to knock
could be dual mass flywheel,if its manual.just press clutch ,and turn off engine,if no noise ,so 100% flywheel.
just tryed that there and there was no noise when i had the clutch pressed in! hmm so what does this mean!?
I wouldn't thinking/hoping it was an engine mount. pop the bonnet & get some one else to turn off the car as you watch for activity under the bonnet. Try to identify the area within the engine bay (if it is in the engine bay) from where the noise is coming from.
My next guess (without seeing the car) would be a loose exhaust bracket.
If you can post up here the general area from where the knocking us coming from I'm sure someone on here can advise better.
