I recently order a Eibach Pro Kit, I hated the gap on the front of my car.
This install was done on a E46 318ci m-sport but it is the same for the rest of the model range.
I only changed the springs in the front of my car as I believe the back is sitting perfect on the 19's and I dont want it any lower.
Result: Very happy with the new stance.
So
The gap
First jack up the car
My lug bolts required a 17 socket.
Using a breaker bar makes it a lot easier
Ensure the car is safe by putting a jack stand under, I did one side at a time
Your strut should look like this
You need to remove this bolt, from memory its a size 16
The bolt hold on your sway bar links
You will need a 16 spanner also to stop the bolt twisting inside the Link. I got away with using a 17 but 16 is the correct size
Push the link out of the way
Now remove the bolt at the back of the shock
Slide the disk assembly down and the shock should now be free
Undo the top bolts there is three of them size 13
The shock assembly should be removable then
Attach your spring compressors
There is a bolt at the top of the hat size 21, you must remove the plastic cover at the top of the strut to reveal it. Once the spring is compressed undo this bolt. There should be no tension on the bolt from the spring.
Eibach vs msport spring
Then reverse above instructions and re-install the shock assembly ensuring you place the disk assemble back to the same height on the shock. A alignment test is recommended. Get this done by a garage with laser equipment.
I am not responsible for any injury you may cause to yourself, this is only a guide to help BMW driver members.
More photos of car finished stance to come once the springs have settled.
BMW new guy
Just finished now cheers.
With the back it wasn't opening up enough so I couldn't get it out....forgot the handbreak was on so it was grand once that disengaged
The front ARB thing is a pain in that arse too haha
Luckily I did ye swap as the rear drive side was broken which I didn't notice as it.
Can you buy a pro kit with just the front springs? I'm lookin' to lower just the front of the e36, I have OEM M3 convertible sprigs I the rear that I bought new last year & I don't want to lower the rear any more than it is.
wont the spring rates be different?
It's not recommended, different designs really- oem aren't progressive springs are they? Id be surprised if there was any damage done though having said that!
