320d 2008 with 70k mls ,tensioner fully out ,noisy.Now its repaired
I've come to the conclusion that no is the answer!Sounds like a major issue surely there is preventative maintenance to ensure this would not happen!
Yeah but is there anything you can do (like change the chain) that wont cost as much if you had to do it after it breaks.. Do ya get meI've come to the conclusion that no is the answer!
I've seen cars that have been serviced every 10-15k and then cars that have barely been serviced. Both examples have broken chains. It's a chain issue, not an oil/lubrication issue like what most other timing chain issues.
Sent from AutoGuide.com App
Ah yeah of course, get the chains/tensioners replaced as they are modified now!Yeah but is there anything you can do (like change the chain) that wont cost as much if you had to do it after it breaks.. Do ya get me
Engine doesn't need to be removed on any model to replace the chains and I'm sure you mean crankshaftThe problem is that on the N47 engine BMW decided to put the timing chain on the rear of the engine against the cabin bulkhead because it was supposed to be designed for the lifetime of the engine and not need to be replaced. I think it can be replaced on the 5 Series without removing the engine but in the 1 and 3 Series to get at the chain the engine has to come out. Replacing the camshaft would require the block to be stripped down afaik. Both are labour intensive and this is where it gets expensive.
So why does it cost so much in labour to do then ?Engine doesn't need to be removed on any model to replace the chains and I'm sure you mean crankshaft
Yes meant to say crankshaft.Engine doesn't need to be removed on any model to replace the chains and I'm sure you mean crankshaft
There's still a huge amount of work involved, remove gearbox, remove rear timing cover, remove rocker cover etc......So why does it cost so much in labour to do then ?
Whats your ball park figure for a 5 series. One thats rattling, not a complete failure.There's still a huge amount of work involved, remove gearbox, remove rear timing cover, remove rocker cover etc......
Pm sent Mulla!Whats your ball park figure for a 5 series. One thats rattling, not a complete failure.
If that happens they could go bust. Its going in more than 30% of their most popular diesel enigne and its a massive job to fix.I think the only way this will be sorted out is a class action case against bmw
Can you tell me when in 2010 the problem was resolved?no was resolved from 2010
If you're buying a 2008 car, why not go for a 325D or 330D? I personally wouldn't touch an N47 car with a really big stick.So im thinking about buying a 08 320d, can someone who knows how to fix this problem before it happens pm me a price please so i can factor it in..
valdes or conor? or anyone else.
