1 - 11 of 11 Posts
E63 Bmw 645Ci
is there any way of sorting scratches in wood trim ??? obviously previous owner threw his keys on the ashtray a lot:mad:
see scratches here
Doktor Displacement
Can you not just pull it off an replace it with another one from the dealer?
Otherwise polish it the same way you would a scratch in the paint.
Like paint. If the scratch is thorugh the top coat then theres nothing that can be done.
Try a fine rubbling compound and cotten wool?
How deep are they?
Off topic but whats your cup holder?
E63 Bmw 645Ci
Discussion Starter · #5 ·
E63 Bmw 645Ci
Discussion Starter · #6 ·
il be ringing them in the morning to find out but realoem suggests a replacement ashtray is only available for the Ruthenium (shiney silver) trim otherwise you have to get the full trim kit costing in excess of €1000:eek:
but thats hearsay until i find out tomorrow
Keep it clean
If it is indeed a wood trim ,the top laquer can be polished right back to the wood. and relaquered. Use Fine grade sand paper. And spend some time at it.
Its quite a slow process but the results will have you smiling.
I miss wood class :(
I don't think it is actually wood trim. I scratched a bit of my trim on my e63 but in a place where you'd never see it unless you were dismantling the dash (between the air vent trim & bigger piece of trim surrounding aircon controls).
I'd say careful fine sanding/polishing on the laquer finish & a respray of the laquer is the only job.
It looks like you cloud be right on the Ruthemheim thing too, screen shot from ETK:
cant you get little filler sticks for wood and then lacquer? You could get a new veneer put on buy a joiner?
try here http://www.formwood.com/veneerexotic.html
I would try polish it first, take it all the way back to the veneer, then re-varnish the veneer with coloured varnish and then lacquer. If you make a mess of it then you in no worse a position than you are at the moment. It would make a tasty diy. A French polisher would be able to help I would say and something that small would only cost a few quid.
1 - 11 of 11 Posts
