Confirmed! Thinkcar2 Bluetooth OBD2 scanner can do DPF generation for BMW 7 Series from the year 2000 to 2018.
Check the Thinkcar2 DPF BMW 7 series car list as below.
What is DPF REG.? When to do DPF?
1.DPF regeneration is used to regularly clear PM (particulate matter) from the trap in combustion oxidation mode (such as high temperature heating combustion, fuel additive or catalyst reduce PM fire point combustion) to stabilize trap performance.
2.DPF regeneration matching must be performed in the following cases:
a) The bleeding backpressure sensor is replaced.
b) The PM trap is removed or replaced.
c) The fuel additive injector is removed or replaced.
d) The catalytic oxygenizer is removed or replaced.
e) The DPF regeneration MIL is on and maintenance is performed.
f) The DPF regeneration control module is replaced.
How to do DPF REG. for BMW by Thinkcar2?
1.Make sure you have downloaded and installed the APK ”ThinkCar Pro” from Google Play or iOS App Store (Android: 5.0 and above; iOS: 9.0 and above)
2.Register and login with the available account
3.Activate the device with SN and activation code, and it will be automatically bound to your account
4.Plug the Thinkcar 2 (Thinkdriver) Dongle into the vehicle’s 16pin OBD2 Data Link Connector
5.Turn on the vehicle ignition
6.Connect device to your phone via Bluetooth
7.Select and download the free diagnostic software for the specific manufacturer of your vehicle
8.Select “Maintenance Functions” -> “DPF”-> the corresponding car model
9.Then follow the prompt to do DPF REG
Please kindly notice:
ThinkCar 2 is a subscription service based on the VIN mode. One VIN code only can be used for one car. Users need to purchase usage right separately if they need to use more cars.
The maintenance service software is purchased separately, and can only be used in the bounded vehicle.
In the case of inactivity, the users buy ThinkCar 2 will get 1 VIN and 2 maintenance software for free.
If you purchase now, buy one new Thinkdriver (Thinkcar 2) get 3 VIN (one VIN can get 2 reset software), so you can get total 3 VIN+ 6 reset software!
Reference: How to Purchase Thinkdiag Mini& ThinkDriver Software?
More info about Thinkcar2 Thinkdriver OBD2 Bluetooth scanner:
ThinkDriver OBDII Bluetooth Vehicle Diagnostic Tool
Product | Special function | Car make | Model | Year |
Thinkcar 2 | DPF REG. | BMW | 730d | 2000 |
Thinkcar 2 | DPF REG. | BMW | 730d | 2008 |
Thinkcar 2 | DPF REG. | BMW | 730Li | 2006 |
Thinkcar 2 | DPF REG. | BMW | 730Li | 2008 |
Thinkcar 2 | DPF REG. | BMW | 730Li | 2011 |
Thinkcar 2 | DPF REG. | BMW | 730Li | 2018 |
Thinkcar 2 | DPF REG. | BMW | 740d | 2001 |
Thinkcar 2 | DPF REG. | BMW | 740d xDrive | 2011 |
Thinkcar 2 | DPF REG. | BMW | 740i | 2001 |
Thinkcar 2 | DPF REG. | BMW | 740i | 2011 |
Thinkcar 2 | DPF REG. | BMW | 740i | 2012 |
Thinkcar 2 | DPF REG. | BMW | 740i | 2017 |
Thinkcar 2 | DPF REG. | BMW | 740Li | 2009 |
Thinkcar 2 | DPF REG. | BMW | 740Li | 2011 |
Thinkcar 2 | DPF REG. | BMW | 740Li | 2012 |
Thinkcar 2 | DPF REG. | BMW | 745i | 2001-2003 |
Thinkcar 2 | DPF REG. | BMW | 745Li | 2002 |
Thinkcar 2 | DPF REG. | BMW | 750i | 2006-2009 |
Thinkcar 2 | DPF REG. | BMW | 750Lxi | 2010 |
Thinkcar 2 | DPF REG. | BMW | 750Lxi / ALPINA B7 | 2012 |
Thinkcar 2 | DPF REG. | BMW | 760Li | 2007 |
