1 - 20 of 25 Posts
Discussion Starter · #11 ·
Tell me about it:)
What's wrong with your own?
I literally glued every part of the door card with sealant but the plastic strip is out by a couple of mm's so the top of the doorcard wont line up with the door..
And ill break the strip if i try to remove it!
driver's side is perfect though
(formerly Orientblaue36)
The plastic strips on mine came off too but I stuck them back on with Loctite 2 part epoxy resin. Worked a treat..
Discussion Starter · #18 ·
Well i used specific panel adhesive but i didnt align the strip properly so the doorcard wont sit right...and the strip is stuck on very well so removing it will cause it to break into tiny pieces:D:D
Oops:(
I tried 3 or 4 different types of glue and had to pry off the whole thing when it didnt sit right and sand down the reminder a few times.. it took a while but the epoxy worked for me.
Getting hold of one grey doorcard with a leather insert was impossible so I had nothing to lose..
Neither have you.
Try it one last time with the epoxy;)
Discussion Starter · #20 ·
Oops:(
Neither have you.
Well i'm very happy with the strength of the stuff...i just messed up:(:D
1 - 20 of 25 Posts
