i am new to this and its my first posting so please dont bite the head of me if i sat anything incorrect
I have a 1992 e36 bmw 320i it was a fab car but i hadnt been using it so about a year ago i loaned it to a friend and of course it overheated.
so i aprked the car for a year the other day i went to use it and
whatever he did to it there was a screw in the top of the radiator that he broke and the water started bubbling out of it so he replaced the screw with a diy job and it seemed to solve the problem of the water bubbleing out but now when u let the car idle about 20mins later it overheats and same if you drive it.
i checked the oil and water for signs of white sludge and there is none but this car wouldnt have travelled ten miles since the first sign of overheating.
so basically whats the first thing i should check or will i presume straight away its the head gasket and go try fix that.
any suggestions welcome as now we have the fine weather and long evening so i am going to try some diy and see can i fix myself and help pass the long evening s
btw def not mechanically minded but will give it a try
any help appreciated
vinny
vinny
